vavle adjustment
vavle adjustment
can any one help with valve adjustment on a 24 valve i had read post on here and one of them said to find tdc is to remove timing cover if thats the case how do you remove the one bolt on cover thats behind pulley or are you to take the cover off blow by tube and if thats the cover to come off how is it on there does it just pull off thanks for yoyr help
Originally posted by rjohnson
It is the cover on the blow by tube...can't remember for sure but I think it just prys off!
RJ
RJ
Intake should be between 0.006 and 0.015 exhaust should be between 0.015 and 0.030.
Do 1-2-4 intake vavles and 1-3-5 exhaust vavles with the indicator on the injections pump nut (Behind the breather housing) in the 12 o'clock position.
6 o'clock position do the 3-5-6 intakes and the 2-4-6 exhausts.
If you give me your fax number I will fax you the sheet out of the service manual.
Good luck.
Justin-
thanks for all the help also JUSTINP20012500 I DONT HAVE A FAX BUTIF YOU CAN SCAN IT AND EMAIL IT THAT WOULD BE NICE TO HAVE my email is jeepfun@echoicemi.com thanks
lucas5477
04-04-2005 11:56 PM
