Vacuum Pump Has Some Resistance After Seal Replacement
Need your experienced help and/or opinion
Is it normal for the V pump to turn freely for 180 deg and then give some resistance for the rest of a full revolution?
I'm asking because while doing the seal replacement I tried to tap the cap back onto the V pump, but quickly realized the shaft/gear end was supported by my bench. I then re-supported the pump by its body and tapped the cap on and torqued the bolts. I used a rubber mallet. Did tapping rather firmly on cap (PS pump end) with shaft/gear supported do any damage?
jimbo486
05-08-2016 06:07 PM
dwatson69
02-03-2009 10:55 AM
