vacuum lines and 4x4 and a/c problems
well i finally got my project ram wreck to a suitable driving point, the only problems i can find is that the 4wd is not lighting up in the cluster, so i think its somthing to do with those vacuum lines on it, i crawled under it and the metal lines that that come from the chunk dont have any lines at the end of them, where do i need to hook to in order to get my 4wd working.
the a/c only blows out the defrost, maybe its something to do with the 4x4 problem, but i pulled the glove box and messed with the the door i could move it but it would just go back down.
any help sortin this stuff out is greatly appreciated
With the rotted hose to the 4x4 actuator, causing a vacuum leak. I'm not completely sure where the actuator is, so all I can say is look around the transfer case.
AC doors not working correctlly indicates loss of vacauum. Check hose from vacuum pump backward too cowl and accross to right. Then back into cab.
ive done some tracing and i cant make heads or tails of this, the guy i bought this truck from had a bunch of dodges so i think he was using parts of it...the vacuum system is all to pieces, does anyone have a diagram on the lines under the hood and the lines on the transfercase?
jimbo486
05-08-2016 06:07 PM
