Turbo Whistle/Whine Louder Than Normal!
Ok, so cruzin' home yesterday from Cougar Buttes my Dodge started to whistle/whine. It was/is fairly intermittent, and doesn't seem speed related, but can be started/stopped by playing with throttle/boost pressure.
I thought that maybe my BHAF had come loose, but no such luck.
The noise was so loud, my friend driving behind me called me on his Cell to ask what was up/wrong!
After a quick inspection I saw nothing.
What do you guys think?
If you have a kid like mine check to see if your silencer ring is still there. I spent weeks changing hose clamps and looking for leaks when mine started making all that noise, only to find out later that my little motor head kid pulled the ring out of it with out telling me.
Check all your hoses and connections for leaks. check your exhaust back pressure too, If it is more than 2 or 3 psi while driving empty and moderate you could have a plugged Cat. The bhaf could account for an increase in whistle under a load.
check the other end, someone might be gaggin ya good with a big ole washer in the tailpipe, that'l whistle like heck, not te metion rais egt's so if its there not too funny a prank.grrrrrrrrrrr sould suk to hav eprank turn into a meltdown mini chernobyl under the hood
FWIW, I saw this on on "another" turbocharged vehicle - the exhaust turbine wheel (inducer) got chipped somehow & the car would absolutely HOWL under boost/load... Maybe pull your downpipe & take a peek..... It could be time for an upgrade!!! good luck...
Common loud leak spot is the lower inlet boot to the intercooler. On some rigs when the boot expands it rubs a sharp body seam. This can cut the boot in such a way that you can't see or hear the leak without higher boost.
dtenorio
12-10-2014 01:01 PM
combat*MP*
16
05-04-2008 02:59 PM
drydocked
10-10-2007 01:17 AM
whatdieseltoget
11-09-2005 10:34 PM
