Truck wont start on incline
Well i just bought a 2002 3/4 ton with 154000miles truck is very nice!
I have been having a problem getting it started when I park it on the slope in my driveway I already replaced the LP it was dead But i am still having a problem getting it started when I park it with the front of the truck higher than the rear! Any advise on what to look for?
Hopefully the IP wasint damaged
Sounds like fuel is draining back into the tank. Try bumping the starter and let the pump run for 10 seconds or so before you try & start it. If that helps, look for fuel leaks from when you installed the LP? Did you get all the rubber washers back?
You are gonna need a fuel pressure gage.
anpconnors
09-28-2012 10:21 AM
052500#1
01-11-2005 04:09 PM
