truck slow to accelerate
hoping some one can help.about three weeks or so ago i started having problem,truck would act like it had a dead pedal leaving red lights stop signs etc. after a few seconds truck would pick up and go noticed that it would start acting like this when truck was hot. any suggestions? thanks
just replaced vp44 about 10,000 miles ago or less checked codes on snap on scanner pulled no codes lift pumped was replaced at same time with the holley pump every one talked about getting good pressure on fuel gauge at idle acceluration and wot.
slow truck
Does the engine sound tinny? Undo the ?? 6 bolts on the APPS and look at the voltage stated on the POT on the back. If you have a multi meter check the voltage on the orange wire at the PCM. The adjustment for it is easy and for the 6 weeks that mine lasted was noticable. It's back to the rev and scream but little power till after 1600. Being passed by a mini van on the hiway before I can get it going is annoying.
I HOPE it's fixable with an APPS calibration, but it sure sounds like a VP44 (especially as it shows the effect when hot); I didn't see a FP gauge in your signature....?
i do have fp guage 14 psi at idle and never goes under 9 psi on heavy accelerate. do i check voltage with key on and no throttle or do i check while working throttle. anyway i hope it is fixable with apps also. just replaced vp 44 and lift pump lessthan 10,00 miles ago. after the 2 or 3 sec dead spot the truck runs like a beat dog and fuel does not go under 9 psi and the motor builds good boost any way thanks for you guys thoughts on this
My truck did the exact same thing. They had to replace the lift pump and the injection pump. Check your codes and see if it shows anything. Even if they just replace the lift pump the vp44 might not be far behind going out.
Justin
2001 lwb 4wd auto 75k
edge ez
afe air filter and torque tube
silencer ring mia
leveling kit
305s and eagle aluminimum wheels
Justin
edge ez
silencer ring mia
leveling kit
would you beleave my dead pedal from red light problem seems to be fixed .pulled out map sensor cleaned and reinstalled due to talking to gentleman at tst truck runs better then it ever has and i bought it new
Bsbruce
11-06-2014 09:30 PM
Greg@RME
41
09-19-2008 07:11 PM
Connotaucarius
11-12-2005 10:59 AM
voidisactive
21
03-06-2003 12:14 AM
