truck not starting
Old 04-06-2008 | 03:58 PM
crash4wd's Avatar
truck not starting
:i have a 98 24 valve truck and just had the injection pump replaced and lift pump and everything was fine but now when i try to start the truck after long period of sitting it takes while for it start like its not getting any fuel but if i let the lift pump run through cycle it starts right up . i took it to local shop and they said that i might have faulty injection pump but i dont think thats it if you have any suggestions it would help thanks
Old 04-06-2008 | 09:33 PM
michcumm's Avatar
Sounds like you've got a fuel leak, allowing air to get into your lines. Double check all fuel lines including return line connections.
Old 04-06-2008 | 10:12 PM
crash4wd's Avatar
thanks but i not exactly sure where thw return lines are ? are they in back of the motor ? i know when it starts it starts right up and doesnt sputter like there is air in the fuel lines and wondering if there is like faulty pump or something that loosing pressure
fourthandgoal
88
12-27-2011 05:39 AM
RED99CTD
04-20-2011 08:08 AM
CRYSTALCRYSTAL
06-04-2008 05:23 PM
abc4yew
03-15-2007 11:55 PM
admin
16
08-17-2003 10:07 AM
Quick Reply: truck not starting
