Truck not engaging front wheels in 4wd....
Old 01-30-2011 | 01:00 PM
xp8103's Avatar
The transfer case seems fine. The lever goes into and out of 4hi and 4lo and I can feel the truck going into low gear. But the front wheels aren't engaging and the 4x4 light is not coming on.
And it's winter here. And snowing.
Help.
Old 01-30-2011 | 01:26 PM
gall087's Avatar
check the front axle area. There is 2 wires down on the vacum shift motor that may have gotte severed. It happened to me when i went through some high bursh.
Old 01-30-2011 | 02:08 PM
xp8103's Avatar
Where is the vacuum shift motor?
Old 01-30-2011 | 02:16 PM
xp8103's Avatar
found it, wiggled the wires (still connected) and rapped on the vacuum with a wrench. Shifts into 4WD now.....
Old 02-14-2011 | 08:38 AM
xp8103's Avatar
Failing to shift into 4WD again. Looking for some input. How much vacuum should be pulled if I were to test the vac lines? I assume that the motor engages and once that happens, a switch is tripped sending the message via the wires up to the dash to turn the light on.
Where are the failure points on these? Is it the motor itself or the vac lines? Where do the vac lines start? My Haynes is pretty quiet on this whole apparatus...
Old 02-14-2011 | 05:21 PM
Lil Dog's Avatar
The vacuum selector is on the Transfer case and run by the lever there. The lines come down from behind the engine to the transfer case and out to the front end along the passenger frame rail. The lines may be ruptured near the vacuum motor or the rubber lines near the transmission cross member.
Old 02-14-2011 | 06:37 PM
ericg's Avatar
Also the actuator itself is somewhat problematic, if you hit it with a wrench and it engaged you more likely than not are gonna need an actuator. They cost about $80 and it only takes about 45min to change. I searched on e-bay got a new $80 with free shipping.
Old 02-15-2011 | 06:42 AM
xp8103's Avatar
I'm thinking (hoping) that if the lines were bad it wouldn't have started working after I rapped on the motor itself. Well, that's what I'm going with at the moment.
Old 02-19-2011 | 10:32 AM
xp8103's Avatar
Vacuum motor housing actually had a rust hole in it. New vacuum motor. Problem solved. Hint, don't put the fork back in backward. It wont engage the axles.....
Old 02-19-2011 | 12:11 PM
TxDiesel007's Avatar
suggestion
posilock it and forget it...
Old 02-19-2011 | 04:43 PM
Tallguy67's Avatar
I second the posilock suggestion. Best $200 and 4 hrs I ever spent (install could have been done in 2hrs but I was being super cautious).
snowwjob1
01-11-2009 07:09 PM
PupleDiesel
06-04-2008 11:29 AM
Meandvls
01-21-2007 10:11 AM
turbo dreams
07-31-2005 08:50 PM
Cumminstd1996
02-02-2004 10:21 PM
Quick Reply: Truck not engaging front wheels in 4wd....
