Truck falls flat at 2500 RPM
I just replaced the map sensor and now I'm not losing power over the whole power band or smoking out the intersection but when winding the truck out in lower gears (on the flat, don't notice it in higher gears) or climbing a steep grade while accelerating in all gears the power goes flat out at 2500 RPM...up until then it pulls really strong. I also had to unplug my Van Aaken as it was acting up but this is unrelated...I have Jammer II nozzles and I thought injectors helped you out up high in the RPM's...
Thanks for any help...
John
John
No this box has no boost fooling ("Smartbox R")...but I have a boost elbow that is still in place...no I didn't reset the AAPS...never heard that before but the VP is 4 months old, this just started. It also seems that while my intown mileage has remained the same my highway mileage has dropped (yes it also dropped when I unhooked the VA box but it just fell off more)
I just looked at the Van Aaken website, they list the Smartbox R as having a boost fooler...
http://www.vanaaken.com/usa/index.asp?pagename=v5r
The elbow only allows the watesgate to open at a higher boost level, that has nothing to do with the what the ECM sees with regard to boost..
A built in boost delimiter is included on both the van Aaken SmartBox™R and the van Aaken SmartBox™V5 for full adjustability.
intuitively, it makes sense, but whether it is actually true or not.....
I do think the motor is being fuel limited. I just don't know by what.
A Bosch Service guy told me that once. Since the VP44 and APPS are the contorl system for putting fuel in when the driver wants it, they need to be recogized by the ECM as a calibrated pair of items for the systems as a whole.
