truck died and wont start
ok my truck died i just bought it and got rid of my first gen so my code is 1639 what is this code and i hope it isnt the vp because this is a bad start for me it has 137000 miles on it so no warranty any help would be great
joe
joe
I've not yet hit the busted Lift Pump nor toasted VP - yet - Try searching for Lift Pump Codes...or just "Codes", there are a zillion posts, SOMEBODY must have seen the 1639
The Lift Pump apparently won't throw a code, and the Dead VP is 0216.
Your sig indicates that you have gauges, was the fuel pressure okay before it died?
What has your initial troubleshooting found? (Fuel pressure at the filter, fuel through the injectors, etc.)
Found the digging I done... I can't find a 1639 code...
1693 - DTC Detected In Companion Module / DTC Detected In PCM/ECM
http://www.troublecodes.net/chrysler/99-01trk.shtml
http://www.troublecodes.net/chrysler/96-01.shtml
https://www.dieseltruckresource.com/...n&onlynewfaq=1
This is the best I can find... I think the code number is a typo... (Is it?!)
Hey, Rauschbo hows it going?
i found the same thing 1693 that is why i asked. i dont know the fuel pressure that is the one gauge i dont have yet i will go buy one today
thanks joe
thanks joe
The 1693 won't turn on the check engine lamp
Most trucks with any type of modification will throw this code.Its because the processors can't make sense of some of the data.All the manipulation of all the info. going in and out of all the modules sometimes dosn't compute.
That sounds familiar my truck is currently in the shop for the same code .Mine has had a 6 month history of bad connections at the PDC.Gotta love that Dodge engineering!!!!!!!!!!!
Did you crack an injector line to see if you are getting fuel to the injectors? If it is cranking with no attempt to fire, this is the first place to look. My VP died without any codes, must have broken a plunger or something mechanical.
TxDiesel007
08-31-2012 11:04 AM
