Truck Died, Need Some Help Please...
Old 07-09-2009, 04:39 PM
phal's Avatar
Mr
Originally Posted by patdaly
DDRP is a good choice for stock replacement.
Unless it is significantly higher, I try and buy from the DTR store......
Check this out:
http://store.dieseltruckresource.com/fadidorepudo.html
And if you happen to think you might need to crack the Injectors alongside the road, buy a cheap 19 MM open end wrench and throw it in the truck. Heck I don't have a 24V and I still carry one, rather have it when my buddy runs out of fuel, yet again.
That is the info I was looking for, I will buy from DTR store if I need the part.
Old 07-09-2009, 04:42 PM
D2 Cat's Avatar
Gary,
The schrader valve you see should screw out just like one on an innertube. I'm thinking it's 1/8" iron pipe thread. That's the same as the extensions you get at the auto parts store for your grease gun. You can get a 12" extension and then go to your test gauge.
If it's a different thread take a hose off a hand air pump and thread that fitting in. Pressure will be about 15 lb max. so pressure isn't a big safety issue.
For a permanent solution you can get a "T" fitting to replace the banjo fitting as shown in your picture on the right side and use SS wrapped hose to go into your cab for a gauge.
Old 07-09-2009, 04:43 PM
phal's Avatar
Mr
Originally Posted by phal
Well I cracked them, the wife turned over for about 12 seconds and there was no sign of fuel.
I have rigged a possible way to check the pressure. I have two connectors in the area that you are talking about. Here is a pic:
Ok, If I remove the conector on the left, should I be able to thread a connector of some kind into this?
.....thanks...gary
I plumbed into the left fitting and had ZERO pressure. Is this the wrong port or am I just getting zero pressure from the lift pump? I checked again, the pump buzzes when giving the truck power, so there is a connection to the electrical.
thanks...gary
Old 07-09-2009, 05:04 PM
D2 Cat's Avatar
Shop manual says the fitting on the left is an overflow valve.
Old 07-09-2009, 05:07 PM
phal's Avatar
Mr
[QUOTE=D2 Cat;2522982]Gary,
QUOTE]
Well, since I didn't see the above before I posted the last one, you will figure out that I checked the pressure on the wrong port. I checked on the big one to the left. This is the fuel return for the VP, correct? I used a tapered pipe thread on this and it felt correct, I was careful when I tightened it down, so I hope I didn't screw anything up.
Since I got zero pressure on the side I thought I was supposed to check, I got gutsy and just disconnected the one on the right. This fitting is connected to the bottom of the filter housing. I turned on the truck and got nothing out of the line, not a drop.
So, does this mean I have a bad lift pump?
thanks....gary
Old 07-09-2009, 05:14 PM
phal's Avatar
Mr
Thank you,
Im not getting any flow at the pressure line at all (line on right in pic), so something is going on downstream.
thanks...gary
Old 07-09-2009, 05:50 PM
D2 Cat's Avatar
The open line with no fuel indicates not pressure at the pump. Only other possibility I can think of is your fuel filter OK? Have you installed a fuel filter in a while? Before buying the pump you could replace the filter. Leave the new element dry and see if you get fuel into the filter body.
There are many choices for pumps and may opinions of what's the best. It all depends on your wanting more HP, your willingness to spend $, etc.
I got a relocation kit from Geno's and put my lift pump just in front of the fuel tank. Easy to get to, easy to change, and the pump is pushing fuel not pulling fuel--making it more efficient. Install a ball valve just before the pump and you can make sure you never have to take a fuel bath when servicing the pump in the future.
Old 07-09-2009, 06:14 PM
phal's Avatar
Mr
I installed a new fuel filter before I started testing.
Old 07-09-2009, 06:56 PM
D2 Cat's Avatar
Then it's lift pump failure.
Old 07-10-2009, 04:53 AM
phal's Avatar
Thanks for the help
I ordered the 1998.5 - 2002 - FASS Direct Dodge Replacement Pump from DTR Performance today.
Thanks to everybody for the diagnostic help!.....gary
Mechanos
12-09-2009 08:58 PM
wyododge
06-22-2009 10:15 AM
RyanF
12-21-2008 03:07 AM
Mini_Donkeys
04-19-2007 12:21 PM
golddusters5703
01-28-2006 01:35 PM
Quick Reply: Truck Died, Need Some Help Please...
