Transmission temperature?
I have a Trans. Temp gauge, newly installed. What kind of temperatures are o.k. and what is too hot when towing a moderate load up a steep curvy road?
Mine shows about 150 degrees F unloaded and about 170 with a moderate load. Keep it out of overdrive so it won't hunt and it shouldn't go above 200 or so. You'll get a "CHECK GAUGES" light at or above 233* F for the engine temp. For your auto transmission you'll get a "TRANS TEMP" light at or above 275* F
OOPS
11-16-2004 07:38 AM
