Transmission..slip going to 2nd..LEFT turn only
Truck: 2001; 185K miles; 2x4, automatic.
Issue: Slipping going into 2nd gear
Symptom: Only occurs sometimes when accelerating into a LEFT turn from a standing stop.
Frequency of occurrence: Once/twice daily...inconsistent. Typically, the first time it happens is about 5 mins after starting to drive in the a.m. I come to a full stop...turn LEFT...accelerate no problems...then at "peak RPM" (1st gear) the engine skips or hesitates (as if slipped into neutral) for 1-2 seconds, then continues to accelerate normally. Only briefly noticeable, but is noticeable hesitation. No problems, issues afterwards.
ODD: ONLY HAPPENS WHEN MAKING LEFT TURN...doesn't happen when turning RIGHT.
Maintenance: Transmission fluid changed regularly ANNUALLY.
Towing history: Periodically I will pull 3 - 4,000lbs (2-3 times per year). No "heavy" towing.
Any thoughts?
Any thoughts?
I agree with jrs_dodge_diesel that it could be your LSD. Sounds quite similar to the way mine was behaving after I changed the rear gear oil to a synthetic oil. Went back to a dino rear oil with 16oz of friction modifier and no troubles since (about three years now).
Cheers!
Mike
Cheers!
Mike
Red3quarter
03-28-2013 10:42 PM
thunderace31
24
05-09-2012 11:51 AM
txsmokindiesel
05-19-2009 08:03 AM
BADodge2003
08-24-2003 07:22 PM
