Transmission fluid changes
I need to learn how to do this myself. The only stations that seem to have ATF+4 is dealers and they price gouge. As people stated earlier Ive found it at walmart but my walmarts dont have auto lube centers. The servicing reccomends Change transmission fluid and filter, adjust bands What does adjusts bands mean? Can somebody chime in and give steps as to how to do this servicing yourself or something
check this thread out .
https://www.dieseltruckresource.com/...d.php?t=137490
here is the band adjustment found in the tech section.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Bands need to be checked everytime you have the pan off- it's likely that you won't have to adjust by much, but have them off adjustment just once and they'll slip much longer during shifts or mess up shift timing. Proper band adjustment is crucial to the longevity of the bands and the clutches in your tranny.
HTH
AlpineRAM
HTH
AlpineRAM
fbx22:
As far as ATF+4, it is available from auto zone, walmart, ORileys. Chrysler had to release the exclusive on it and so it is available all over at about $5. per quart. Even Walmart brand (Super Tech) has ATF+4 and its about $3.
( to be sold as ATF+4, it must be that grade, and so don't be afraid of the off brand) Walmart sells the Mopar brand as well as the Super Tech. Valvoline has it too. Hope this helps you.
t_george77
06-26-2010 07:36 AM
vander
06-11-2010 05:14 PM
