Transfer Case fluid amount
Re:Transfer Case fluid amount
What kind of fluid do you put in the transfer case? It's the only stock fluid I have left in the truck... might as well change it out too! ;D
Tony
Tony
[quote author=TPilaske link=board=4;threadid=21302;start=0#msg199844 date=1066852904]
Tony
[/quote]
ATF +4, Tony. Valvoline MaxLife ATF is +4 approved as I understand it, but doesn't state so on the bottle. It's in their web site however and it's a heck of a lot cheaper than MOPAR.
It holds a little less than 3 quarts.
Tom
Tony
[/quote]
Tom
[quote author=TPilaske link=board=4;threadid=21302;start=0#msg199856 date=1066855657]
So I could just use some Amsoil Universal ATF eh?
[/quote]
Tony Yes!
3 quarts, thanks!
KC
[/quote]
Tony Yes!
3 quarts, thanks!
KC
I'm running big A's universal ATF in my T-case.
Here's the capacities:
NV241 Standard- 5 pints
NV241 HD- 6.5 pints
NV241 HD w/PTO- 9 pints
I've got the standard. The data tag in either the glove box or on the underside of the hood should tell you which T-case you have.
NV241 HD- 6.5 pints
Would it say with PTO if my T-Case Has one?
Just trying to figure out if mine has the PTO.
Also will it just fill till it's full or is there a certian level?
One other thing where can I get the Max Life =+4 Approved stuff!
Thanks
DRecu!
Thanks
DRecu!
I doubt you have PTO and don't know about it. You'll just have blocking plates on the sides of the trans where a PTO would mount. This means you have capability for PTO mounted accesories.
PTO = Power Take off. This is for running auxilliary pumps etc. for accesories like snow plows etc.
Years ago I had a Scout with a Ramsey PTO winch. God I would give anything to have that system back. 3 speeds in, reverse out and a whoopping 86 horsepower winch with 80K rated drum. It was apleasure pulling people out instead of a chore.
[quote author=drecu link=board=4;threadid=21302;start=0#msg200144 date=1066882997]
............One other thing where can I get the Max Life =+4 Approved stuff!
Thanks
DRecu!
[/quote]
I got mine at Wal-Mart for $2.88 a quart.
Thanks
DRecu!
[/quote]
Dorkweed
02-20-2006 05:07 PM
