trans hunting for gear
Old 07-29-2007, 08:43 PM
ajg617's Avatar
Originally Posted by Nor_Cal_Angler
i did the same think about a month or so ago....i got lucky and didnt blow the fuze...just arched a little.....about a week after that i got the surge....i wraped the BLACK W/ TAN stripe wire comming from the ALT. to the NEG TERMINAL on the PASSENGER battery....problem gone has not surged once and i have towed 7k boat and trailer over hill and along coast line HWY, flat land and everyting in between...
NCA
I just had the oil changed two days ago (Yeah I know I should do it myself).
Old 07-30-2007, 04:58 PM
ajg617's Avatar
Thanks to all of you. I would never have believed it. I did an apps reset and foilover on the ground to the alternator. Cured the torque convertor problem and made a huge difference in performance. As I pulled away from the house after doing that I heard my turbo kick in for the first time in months - just hearing it made me realize that it had been relatively silent for a long time and I'd just gotten used to it. Also, almost no pedal effort needed to go up hills that I had been pushing down a bit on before. Remarkable. Kudo's to whomever discovered these links and to the forum for making it available. I can't think of how much I would have spent at the dealership.
regards,
AJG
Old 07-31-2007, 01:18 AM
Mike Perez's Avatar
What do you wrap the wire with, aluminium foil?
Mike
Old 07-31-2007, 09:42 AM
febrocks's Avatar
One more question. Did you cut the loom wrap to wrap all that alt. wire or just the wire that's exposed?
Eugene
Old 07-31-2007, 01:25 PM
ajg617's Avatar
Yup used good old Reynolds Wrap aluminum foil and I only wrapped the exposed portion of the wire. No hunting for gears and truck shifts a whole lot crisper.
Old 07-31-2007, 02:25 PM
febrocks's Avatar
Thank you. Been dealing with this for awhile. When I installed the EZ, it actually stopped but then started again last week.
Eugene
Old 08-01-2007, 09:05 PM
fordpowermuscle's Avatar
My 99 does the same thing. It wasn't too bad until I installed a Glacier lift pump and it went from bad to worse. Tried resetting the apps, worked great until shutdown, after restart same ol same.
I went to the store bought some foil and electrical tape to try. In the process of describing what I was about to do to my 14yr old son. I pulled the black wire with a tan stripe up a bit to point it out. Maybe a half inch or so. Well something came up and I just closed the hood and went on about my business. That's been two days and 300 miles ago and the trans is working great!!!
So now I'm thinking it had nothing to do with the pump install, just that when I pulled off the ground cable on the passenger side I got the black wire closer to the alternator. If just pulling the wire away some fixed my problem then would the aluminum foil really do anthing?
Thanks!
07BigHornRam
35
01-27-2011 10:45 AM
triumph74tr6
Introductions / New People
10-27-2009 07:43 PM
RedRacer44
12-15-2007 10:19 PM
RedRacer44
12-10-2007 11:09 PM
Quick Reply: trans hunting for gear
