Trans Help!!!
Trans Help!!!
My 2001 CTD that I pull with every day with 250,000miles is experiencing transmissions problems, what is happening is it will shutter(like a slipping TC) when accelerating & in 4th if I slow down to about 80KM/H and accelerate to 100KM/K and beyond the RPM will jump about 100 then lock then another 100or 200 then "grab" again. I can visually see this with my tack and I can hear the motor. What do you think it going on? The only mod it an EZ. I think its the TC slipping,if I do the TC should I do the VB as well?
It shifts no different.
I had a shudder in my 06 with a goerend tranny in it. This may sound weird but this honestly fixed it.....
Dave said to put a tube of Shutter (or Shudder) Fix in it. I bought it at NAPA. Its in a red tube that is slightly smaller than a tube of tooth paste. cost $6. shifts perfectly now. Try it.
hi
check fluid level first !
then do a scan for codes !
tps or aps checkout !
how long filter / fluid change ?
a vb kit is always a good idea !
does it do it w od off ?
Is this the stuff?
http://www.napaonline.com/NOLViewer/...440&ShowPics=1
I couldn't pull up the link. If you want give me a call tomorrow. Maybe we can trouble shoot over the phone. We have done about 10 tranny swaps and repairs in the past month, so maybe I can help.
Mike 678-521-6601
Mike 678-521-6601
Les Eid
02-13-2008 09:22 AM
nfsommer
11-09-2007 09:36 AM
djgaston
10-30-2005 03:18 PM
live wire
07-21-2003 07:26 AM
