Trans and Diff Oil Change
I am going to be doing a lubricant change on the transmission, transfer case and the front and rear differentials. Is synthetic the best way to go? What about the friction modifier for the rear? What brands are good? Am I going to have to do a second mortgage?
Re:Trans and Diff Oil Change
Go to Dodge and get the Mopar Modifier. It should take about 3 for the rear if you have a Dana 70 and 2 for the front on a Dana 60. Mopar brand is the only one that will work 100%. Have fun it's a big mess Dodge Trucks are the only truck I have and will ever run trust me get the Mopar Modifer
From everything that I have read, synthetics are the way to go because they help so much with heat and they do not break down like the regular fluids. I have Mobil 1 in my tranny and both diffs and have had no problems. Alot of guys run Amsoil, Redline, etc. I am sure that you will get alot of different opinions here. Good luck.
When the truck was new it had a rear end problem which required it to be overhauled. They forgot to put in the friction modifier and it chattered really bad in sharp turns. Also, as I understand it, the rear diff is the only one requiring the modifier. Is this correct?
If you go the Amsoil route the friction modifier is not usually needed, though Amsoil just came out with a new product called Slip Lock that can be added to any gear lube to eliminate chatter. It comes in 4 oz bottles and treats differential with 2 to 4 quarts.
On the ATF, I've seen temperatures reduced 20-50 degree while towing and other high load applications.
NJMurvin
11-02-2006 04:24 PM
ViperSBT
06-04-2004 07:21 PM
