tranny line question and gauge install
well from what I can see from looking at back posts is that i want to use the front line or the one that goes under the pan.<br>I plan on teeing in with compression fittings , Is this the correct line? Also it comes out goes under pan and goes to a black cylindrical object then comes back under the pan and heads towards front cooler. What is the cylinder it goes to and should I tee before or after this? Still waiting on delivery from genos but want to be ready when the gauges arrive
Re:tranny line question and gauge install
Ok went to DTT thru link on this site , all questions solved now , guess I should have looked first. This is a great site .
for a real easy and clean install get the factory cooler line from Dodge. The sender screws right in, no fuss.<br>Tim
well I did go with factory line , just couldnt get fittings I wanted for a clean looking install , and I guess It was my lucky Day, Dealer has been absorbed by a mega dealer and moved twice within last year and parts guy said he was tired of hauling this piece around. So I got factory line for $72.00<br>I think thats hard to beat and it just about fell into place
I haven't looked at it yet so maybe you guys can give me an idea... How difficult is it to swap the cooler lines?<br><br>Thanks,<br>Russ
very easy , did not go with the stainless line from DTT yet left it with factory rubber hose/tube combo factory line has check valve in hose my truck also had one in cooler , removed cooler check valve left one in factory line.little messy with the fluid(and I hate tranny fluid)but half hour job tops
dieselfuelonly
07-25-2007 06:30 AM
rjm022
19
04-06-2007 01:23 PM
CRIVERHD12
06-15-2005 09:37 PM
Flatty
04-25-2005 02:17 PM
