Tranny jumping out of OD?
First time I ever noticed a problem. 50MPH, light throttle pressure, the OD seemed to slip in and out very quickly about 1 second then engage again. Fluid level dead in the middle, and its time for a flush, any ideas tranny guys?
do a search on transmission problem or shifting problem. It's likely electrical noise, dirty battery terminals, low batteries, governor pressure sensor and/or solenoid, etc.
You'll find something. Could just be the hairy edge of overdrive and you're lugging the motor a bit.
You might try this,,, APPS Reset. It's free and may help.
Question= Will the TPS "learn" a better shifting points or did this proceedure teach it something permenant? Is there a time that is specified for the correct shifting pattern?
My problem turned out to be the throttle position sensor. It didn't throw a code either but it was bad. I guess this is common. At least, replacing it fixed the shifting problems. Make sure that you have eliminated all other possibilities as it is a $450.00 part.
I dealt w/ that problem for a while, did all the normal stuff....APPS reset, battery terminals, etc. Finally I ran an extra ground from the PCM to the body and neg. terminal on the battery and it NEVER did it again. Mine was really bad w/ alot of accesories on, with the AC on it would jump out of OD at 60 MPH!
flyingd
09-16-2014 05:59 AM
kyot
09-07-2009 12:48 AM
