Tractor hydrulic fluid for power steering
Old 03-06-2007, 04:01 PM
jlebrun's Avatar
my truck has a bad whine in the power steering and when its real cold out, i cant drive it for like 10 minutes otherwise it shoots the power steering fluid out. i bought some valvoline synthetic blend today and i will see if that helps. besides sucking what you can out of the reservor, is there any other tips to getting all of it out, or will emptying the reservor be enough?
Old 03-07-2007, 09:47 PM
LUKE-MM-PULLER's Avatar
it sounds like you have the same problem I had, water in the pump. What I did was, took off the return line off then started the truck and turned the wheels all the way to the rightand let the pump MT out. then I filled the Res. and did it again. after that I cut enough off of the return hose so that it wasn't higher than the resivior, and filled it up, I haven't had a problem since.
ckt_santiago
12-26-2018 03:55 PM
linetrash75
14
04-10-2012 04:34 AM
Tiny Ram
03-03-2011 07:40 AM
Tommy93w350
06-26-2007 04:42 PM
BLK_RAM
01-18-2003 10:14 AM
Quick Reply: Tractor hydrulic fluid for power steering
