Tools needed for VP44 change?
Old 07-20-2006 | 10:57 AM
Adam84's Avatar
I should be getting my new injection pump this week end, and I was wondering what tools I will need to change it. It would be great if one of you could just give me a list if it is more than one item so I can just order / buy them all at once, because right now I own zero tools.
Just pretend I know nothing about tools, or trucks. (Because I don't)
Old 07-20-2006 | 11:01 AM
Mcmopar's Avatar
Do you mean you have NO tools, or no specialty tools?
Old 07-20-2006 | 11:34 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Check this thread.
It should answer all of your "How To" questions.
https://www.dieseltruckresource.com/...d.php?t=109032
Old 07-20-2006 | 11:36 AM
yarddog's Avatar
See this thread:
If you don't know anything about tools or trucks, you might want to let a mechanic handle this one
EDIT: shovelhead beat me to it!
Old 07-20-2006 | 01:34 PM
team's Avatar
I just changed mine out a few days ago. It is fairly simple just take your time and label all the high pressure lines so you don't have to take the time to figure out where they go when u put them back on. ALso, you don't need to take off injector line number 6 from the injector, just the pump. And, turn the engine over by a crankshaft bolt, the alternator nut didn't work for me,it just slipped on the belt. go buy a steering wheel puller from northern tool or somewhere else. I bought mine from northern tool for 4 bucks. And a 27 mm socket for the ip axle nut, this cost me 2.88 from northern tool. Everything else is pretty much standard metric stuff. If you have any questions let me know.
Old 07-20-2006 | 01:39 PM
pmtg's Avatar
i believe its a T45 torx bit to take the mounting plate off of the bottom of the injection pump. well, torx bits were what was holding my 2001's on.
Old 07-20-2006 | 02:16 PM
Mcmopar's Avatar
Yup, that's what I have found too.
Old 07-20-2006 | 04:08 PM
Adam84's Avatar
Wow
Thanks for the info guys that thread will come in handy.
After reading it all I may just let the dealer do it though... lol
I wonder how they will feel about me bringing a pump in I bought for $600.00 cheaper than what they wanted for one just to have them put it in.
I didn't see that thread in tech facts, I might have missed it, but maybe it should be added?
Old 07-20-2006 | 05:05 PM
scottsjeeprolet's Avatar
If we knew where you lived one of us might be close by and help you do it.
i'd be more than happy to help, and i have some tools too.
Old 07-20-2006 | 05:25 PM
smokindog's Avatar
Yeah, it really isn't a tough job and with someone who has done one before assisting it could easily be done in a couple hours. Be warned that the dealer will be charging you the book rate which I believe is going to be around 4 hours. I did mine in about 2.5 hours and that included lunch!!!
Old 07-21-2006 | 01:07 AM
Timmay2's Avatar
I did mine in my driveway for the first time in a few hours.. and that included "making" my own plate to pull the gear off the injection pump.
Its not very difficult at all.
eichhoma
01-27-2019 01:39 PM
buckman361
03-07-2008 11:44 PM
Roadrunner
02-21-2006 04:25 PM
texasaggie2005
08-22-2005 10:39 PM
eswartz
02-23-2005 02:19 AM
