timing of Injection pump
I've got a 2000 - 3500 dually that I bought with a injection pump thats been replaced. I really don't think it's got the giddyup and go that it should have. My question is, is there anyway to check timing ?
other than that maybe the key on the vp44 shaft is wrong
The key comes from the rebuilder with numbers that match the pump. MWFI sends their key installed correctly with the arrow pointing towards the pump. You have to be not paying attention to screw it up. You could pull the front cover to make sure everything is aligned correctly but I'd look elsewhere.
Got any codes?
tommurray
02-23-2014 10:38 AM
