Throwing codes on a new reman vp
MY vp44 just went out last week and I had a new reman bosch vp put on. I decided I wanted to have some fun and crank up the adrenaline a few levels. The truck kinda started to miss like only when I was giving it gas. Then the Check Engine light came on. So I ran my code reader and these two codes came up
p0253 - P0253-FUEL INJECTION PUMP FUEL VALVE OPEN CIRCUIT
p0216 -injection pump failure
Could a brand new reman pump be bad? Fuel pressure is around 13-14psi. Any one have any ideas? This would suck if I have to buy another vp
I had thrown codes yesterday on p0216 and 253 but I cleared them an they havent come back. Im not sure if the codes have been cleared before the vp was changed or not.
I just ran the truck again no codes, I dont think the 216 was erased before the new pump went in. But when I go to level 3 on the pulse the truck bucks and the check engine light comes on and I get
P0253 - injection pump metering control A low
Could the shop that installed my vp have installed it wrong? Could the timing be off? The truck runs solid on level 1 and level 2 with the adrenaline. OOO this sucks trying to figure this out.
PO253 -
Usually means the IAT sensor inside the VP-44 is not functioning at spec. Slight possibility that it's a problem with the ECM. Sounds more like there's a sync issue with your box.
I am unaware of an IAT sensor in the VP44!
My suspicion is that your rebuilt pump does not have a new housing with the linered delivery valve and may have a blown front bypass diaphragm. Either situation will result in low metering levels, and they can run just great for a few miles to a few years before they crap out.
The housing can be quite worn, or have a blown bypass diaphragm, and still pass the acceptable level of pressure test on a bench. Only the first rate pump builders replace the full housing to avoid this problem.
I've held the remains of an IAT/speed sensor from the VP-44 in my hand.
From dodgeram.org:
The fuel pump control module (FPCM) responds to the ECM's commands by consulting the fueling data and timing in its memory and actuating the fueling and timing solenoids. A fuel temperature sensor is located inside the VP44 pump to compensate for changes in the temperature of the fuel. The pump also contains a speed sensor (IAT) that gives the fuel pump control module (FPCM) data on the position and speed of the pump shaft. A reference pulse that marks top dead center (TDC) of cylinder No. 1 is sent from the ECM once every pump revolution. By comparing this reference pulse from the ECM to the position signal from the speed sensor (IAT), the fuel pump control module (FPCM) can reference the pump's position in relation to the engine's position. This allows the fuel pump control module (FPCM) to adjust the pump timing to compensate for minor position differences between the fuel pump shaft and the engine camshaft. If the difference between the pump position and engine position becomes too great, then a fault will be logged in the fuel pump control module (FPCM).
If the reman VP-44 was purchased from a Bosch-certified rebuilder, the possibility of worn or warped housings or blown diaphragms is small. The IAT/speed sensor, on the other hand, is an electronic component that will either fail quickly or last a fairly long time.
From dodgeram.org:
From dodgeram.org:
From dodgeram.org:
Thats what I think Im going to do. Which totally sucks another vp I have to buy. When its cold out and the truck isnt plugged in it romps and seems like it starving for fuel. RPMS bouncing ideling like it has a huge cam. When its in reverse its almost dies out but after a few mins the truck will run fine.
User Name:
16
09-18-2009 06:25 PM
ssleeper94
11-11-2005 11:47 PM
gatf4
03-22-2005 02:00 PM
