Throtle Position Sensor and Auto trans shift
Old 08-16-2008 | 04:11 PM
GSP's Avatar
GSP
My '99 just started late shifting to 2nd and 3rd, not shifting normal and motor revs longer before shift some times.
Could this be The Throtle Position Sensor is bad and needs cleaning.
Any photos on cleaning the TPS . I still need to get a Manual so any pictures would be appriciated
Also, what is " the Pot" ive read this several times about the TPS, can someone inlighten me?
Old 08-17-2008 | 11:02 PM
dozer12216's Avatar
Might want to do KD band adjustment just to see where it is. When the KD band gets loose a complaint like your surfaces. When no threads protude boyone jamb nut on KD adjustment, the band is worn out and tranny ohaul required. Don't keep running in this condition. It gets more expensive to repair.
Old 08-18-2008 | 03:55 PM
tx_2500's Avatar
Its the bands.
Listen to dozer. mine started doing that and while it wasnt THAT much more, I had to get some parts replaced because my band wore clean away before I got it in the shop.
Old 08-18-2008 | 07:16 PM
GSP's Avatar
GSP
Nope It aint the bands. I just checked both bands adjustment a while back for the heck of it
Also , someone inlightened me that my 99 doesnt have a TPS. It has a APPS
Found I got P0720 code. I replaced the speed sensor. Shift problem curred, so far, no more check engine light so far on test drive. Seems to be fixed
Old 08-18-2008 | 10:04 PM
turbo246's Avatar
Check the thottle valve cable adjust the play
Doug Crall
0
06-09-2008 08:04 PM
Bad Ramer Jamer
11-26-2007 11:00 PM
dieselrob
09-11-2005 11:38 AM
stone
11-23-2004 10:00 PM
mikal711
02-09-2004 08:55 PM
