Thread pitch for VP44 gear?
Old 05-11-2006 | 04:31 PM
yarddog's Avatar
I'm getting everything together to replace a dead VP. I bought a small T style steering wheel puller that should work to pop the gear off. I want to make sure I have the right bolts to thread into the gear. Any help is appreciated!
Old 05-11-2006 | 04:46 PM
piperca's Avatar
M8-1.25, mine came in the kit with the puller.
Old 05-11-2006 | 04:54 PM
yarddog's Avatar
Thank You!
Old 05-11-2006 | 05:41 PM
Viesel's Avatar
I did mine last night and I was told by the cummins mechanic at Southeastern power systems that I didnt need a puller. Just loosen the main 4 bolts and the bracket at the bottem and loosen the pully bolt some and tap on the 27mm nut with a ball pin hammer and it pops right off. Mine did with no problem.
Good luck
Old 05-11-2006 | 05:53 PM
dodgetech77's Avatar
Good luck
That would work but theres only like 4 inches of room between the shaft and the fan shroud
Old 05-11-2006 | 09:31 PM
Viesel's Avatar
Yeah but the four inches was enough to get it done. You dont have to tap very hard.
Old 05-12-2006 | 11:30 AM
yarddog's Avatar
Another great tip, I'll give it a shot.
schoust
10-21-2009 10:09 AM
lgp9999
12-28-2008 11:09 PM
1-5-3-6-2-4
01-25-2007 09:52 PM
Diesel-Dan
04-05-2004 02:18 PM
Diesel-Dan
03-31-2004 09:57 AM
Quick Reply: Thread pitch for VP44 gear?
