is there anyway to tell if ......
Old 06-15-2005, 11:42 AM
Muted User
scarecrow's Avatar
is there anyway to tell if your lift pump is going bad if you donot have a fuel pressure gauge??
Old 06-15-2005, 11:44 AM
Tazman's Avatar
Usually not. It's the "silent killer"
What's your's doing (or not)
Old 06-15-2005, 11:50 AM
CTD NUT's Avatar
If the LP is completely silent, it is smoked......and if it is abnormally loud and makes growling sounds and the pitch is inconsistent, it is probably just about cooked, if not completely. Still, there just really isn't a suitable substitute for a FP gauge.
Taz,
Did, you get your motor up and running yet?
Old 06-15-2005, 11:53 AM
Muted User
scarecrow's Avatar
my truck is running great. i just want to know what to keep an ear out for..
Old 06-15-2005, 12:07 PM
graphitecumnz's Avatar
how about just poppin' for a fuel pressure gauge??
Old 06-15-2005, 12:26 PM
Commatoze's Avatar
When you change the fuel filter and it won't start afterwards.....RIP LP.
Old 06-15-2005, 01:11 PM
Mike D's Avatar
Get a gauge, much cheaper than replacing a IP.
Old 06-15-2005, 01:34 PM
Muted User
scarecrow's Avatar
i am working on the gauges it`s just money is tight right now...i am gonna do the pillar w/ egt, boots, fuel pres.
Old 06-15-2005, 01:35 PM
TRAVIST's Avatar
BD sells just a pressure light kit. Comes with all fittings and when the light come on then your pressure is too low. www.bdperformance.com
Old 06-15-2005, 03:55 PM
Clunk's Avatar
If you wanna go cheapo while savin' up for the nice guage pak, go to a heating & cooling supply house and get a rubber 8ft. freon 12 fill line...seems like they're less than $20. They have guages too so get a 0-30 psi one to fit the line then screw the other end onto your Schrader Valve under the black cap on your injector pump. I used a fuel pressure test kit, grease gun line extensions and a good 0-30 psi guage from a friend.
I didn't think about the freon line until I visited a heat/cool supply house then asked about the line for future reference.
Old 06-15-2005, 08:39 PM
Muted User
scarecrow's Avatar
if all is well where should my fuel pressure be at?
Old 06-16-2005, 02:52 PM
Clunk's Avatar
Most folks agree on 12-15psi idle and 8-10 psi at Wide Open Throttle (WOT).
Old 06-16-2005, 08:36 PM
Haulin_in_Dixie's Avatar
I could find nothing at that site except links to other sites.
Old 06-16-2005, 10:54 PM
BigBlue's Avatar
I bought a fuel pressure gauge for a gasser from o'reillys for $50.
Old 06-17-2005, 10:34 AM
Korney's Avatar
http://www.hoeslidiesel.com/
These guys got that low pressure LED set to 5 pounds for $58 American. You can call him and he's a good guy to answer everything. He also has great prices on new lift pumps of all brands.
Quick Reply: is there anyway to tell if ......
