Temperature probe connections
Old 07-05-2003 | 10:33 AM
RHC's Avatar
RHC
Is there anyone that uses a temperature probe connection that is not in the fluid stream? A probe connection that is attached to the outside of, say a trans line.<br>I know there will be a small amount of temp differance, but just not ready to cut perfectly good trans lines . Me and plumbing don't get along very good . Have fears of didn't make the connections good enough and a million miles from nowhere and i just pumped the last drop of trans fluid out on the road. :'(<br>But i do want to install some type of temperature monitoring for my transmission and turbo.<br>
Old 07-05-2003 | 12:06 PM
Stamey's Avatar
Re:Temperature probe connections
Think about this. I grabbed it someplace and have not actually tried to get the part though.<br><br>Dodge Transmission Line<br>This line, or part of a line, has the fitting in it to put a temp gauge sender in the line.<br>Part # 5011244AA<br><br><br>Chris
Old 07-05-2003 | 08:06 PM
awmasparky's Avatar
I agree. I didn't want to cut the line either, but needed to get it done. I'm an electrician(who would've known) and I got mine in yesterday. Works fine now.
Old 07-06-2003 | 02:04 PM
RHC's Avatar
RHC
awmasparky, I am an electrician also. What kind of work do you do? Could you e-mail me how you installed the temp sensor's, and what brand of gauge/gauges you used. What are you monitoring trans, turbo or both<br>
Old 07-06-2003 | 02:51 PM
WVPANHANDLER's Avatar
Also would be interested in a e-mail on how the install<br>the inline probe for reading temps for the transmission.<br>What type of gauges used, lines connections and parts<br>needed. Wayne
Old 07-07-2003 | 06:03 PM
apc's Avatar
apc
Factory crossover line is the way to go. Knocked check valve out of cooler fitting and left one in the rubber hose. Di Pricol<br>gauges in A pillar mount. Painless wiring kit to power sender.<br>Tapped into cig lighter for gauge lights. Highway driving , no towing yet. stop and go will hit 180 but once up to speed falls off rapidly.
tomd
12-12-2006 10:56 PM
BuckBoardDriver
07-27-2003 09:50 PM
Hummin Cummins
21
03-28-2003 03:22 PM
Grampaw
02-05-2003 09:28 AM
Commatoze
12-22-2002 07:26 PM
Quick Reply: Temperature probe connections
