tell me if i got this right
I was following a truck today and had to slow down to wait on it to turn. Step on the accelerator and uhh yep no power. I seen my life flash before me , oh no that must of been the dead peddle i read about all the time. Wait i go into denial just need to down shift, come on why is it not gaining speed.I can barely creep up the hill. Quick check the boost guage i must of blew a boot off. no boost fuel pressure 14psi. hay i'm picking up speed must of been a fluke.
have to slow down again, same thing no boost no responce on the throttle i'm getting some worried now. still have to make it home . get home no codes thrown.
Pleasssssse tell me it aint the vp44. Wait don't just tell me, prove me wrong.
1 tank of ultra-low and now this. anything beside vp44 model i need to know when looking for a replacement. Will try the apps reset tomorrow.
Ok yesterday i got a CEL and used a OBD11 scanner and pulled up a P0237. What would of caused that? I did clean the battery terminals before the cel came on. I have not drove it today after erasing the code. Could it be in the edge comp ? where else would it sence the low input?
When i had the first low throttle symptom i had zero boost on the gauge and no smoke that i could see. We all know how well you can see out of these quad cabs with the excellent factory mirrows.
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1 Post
P0237 is boost circut issue. Check the MAP sensor and the plugs. Does the Edge not respond well when the MAP sensor isn't sending a signal? Maybe somebody knows?
P0237 - "Turbocharger Boost Sensor A Circuit Low"
Hopefully, someone else will chime in and verify but I think circuit A refers to the 5 volt input supply wire to the MAP sensor which comes from the ECM. I don't know what the possible causes of this are other than something is wrong with the ECM itself....but again, I'm not a DC tech and I'm not up to par on my ECM diagnostics.....J BODY, where are you?
Mine is also throwing this code. I fixed the obvious grounds around the batteries but have no idea where the other critical ones are. I don't have any dead peddle feeling. Just a rough idle and miss that comes and goes depending on the day.
Keith
Keith
jmccart
13
05-05-2008 04:17 PM
00Dog
09-19-2006 05:21 AM
1stdodge
20
02-23-2006 07:17 PM
