TCC or OD Solenoid Performance
I have gotten the P1740 code- ( TCC or OD solenoid performance) Several times . Like 5 or 6 times. My tans is stock with less than 30,000 miles overhaul under warrenty at the dealer. It was done by the previous owner.
The transmission is working great. Just get the code after driveing around town stop and go.
Usually I have the OD off unless i forget to . It only throws the code if I leave over drive on in city driveing . But OD and lock up seem to work great.
Any ideas whats causeing this? Eventualy I will beef up the trans maybe Goerend bros TC and VP etc.
Is it a California truck(check the engine data plate, and see if it has emissions data under CA)? When you come to a stop what mph does it down shift to first (should be around 10 mph)? Does it usually only set the code when cold?
Paul
Paul
Paulb , Yes its a from Ca truck. And yes I think it only troughs the code when cold maybe. It just happens on surface streets near my house going to the bank ,post office, grocery store . Ive never noticed the check engine light actually go on just when I start the truck again from going to a store.
Not sure the speed of first gear down shift but 10 mph sounds about right.
Ive been keeping OD off. Till I get on the freeway or where my speed goes up above 45 mph on more open roads. Trans works fine and doesnt through the code. Just went on a 4 hr drive and up steep mountain roads. Trans worked fine no codes.
Just around down slow driveing very light foot on the throutel
Any Ideas.
Thanks Rick
Any Ideas.
Thanks Rick
Any Ideas.
Thanks Rick
Any Ideas.
Thanks Rick
If everything else with the trans works correctly then I wouldn't worry about it. You will shortly learn how to drive it so that the code doesn't set.
Paul
I have the same code popping up on my CA truck. My problem is that the orange/ blk wire that commands the soleniods is working properly but my truck does not drop rpm when truck goes into lokup in 3 or 4. it just started doing this.
SLSD400exGUY
10-13-2011 06:50 AM
aborgardt
09-15-2009 12:18 AM
kevellis32
03-25-2007 09:54 PM
