Tach Speed Cluster problem
Today while driving, I noticed the whole panel cluster with temp,tach,speed,etc going krazy, up and down, flashing lights, beeping, tach jumping from zero to 1500, all kinds of stuff---what wrong? It did it at Idle as well as speed.
I have a 99 2500 4x4 ctw 173000 miles with the 6 speed q cab long bed.
thanks
Stix
thanks
Stix
stix - I just recently been having the tach drop to 0, then after sometime come back. I can hear what sounds like a relay clicking from the fuse panel on the left end of the dash. Sometimes the tach won't fall all the way to 0 before it comes right back. For me it usually happend about 1/4 to 1/2 mile after starting out on a cold engine. And doesn't seem to happen at all once the truck is warmed up. I'm also getting the check engine light and P1696.
Thanks. Further searching has led me to the crank position sensor. A couple questions:
1) How much does a sensor cost?
2) Where is the sensor located?
The reason I ask about location is because the ABS sensor is located on the top of the rear differential. And, the rear diff turns linearly with speed ... meaning sitting at a stop light with the engine idling, the tach would be at zero. The rear diff doesn't seem like the right place to put the cps.
Katmandu
10-09-2019 10:21 AM
