switch
switch
has any body out there replaced the switch that will not allow the starter to operate untill the clutch is depressed? if so , where is it? i am having intermitant starting problems...it could be the starter motor or the switch .i already have the larry b. kit ready to install
any pictures would be helpful...... thanks guys
It's on the steering column up against the fire wall. If you get under there and look you can see it. I've disco'd these on other vehicels and all it took was removing the plug and putting a U peice of wire in the plug. I haven't done this on the dodge just because I have kids and if it started in gear the massive torque of the cummins could push the truck all the way through my house
John, it wraps around the push rod. Remove the white slip cover and it snaps off the rod. Takes only a minute to remove. Give me a call if you need one. I've got an extra, somewhere.
Bart
Bart
92smokin blacky
09-01-2010 09:55 PM
Barryn
07-14-2008 09:30 AM
