Swapping Vp44, tools needed?
Hey guys, I am just wondering what size flare wrenches METRIC OR SAE I need? I am also nervous being my virgin swap.Any tips so I don't screw up? Thanks If this goes well I will be a happy camper.
The pump is very staright forward to change, the only special tools would be the gear puller. Other than that a stubby 19mm will really help with removing the injection lines from the pump (take them off in sets of 3 so they thay bolted together). You will also need a torx bit (don't remember which size to remove the mounting braket from the old pump and install on the new one). If you have a service manual it give a great description for the R&R, if you dont have one it can be purchased at Techauthority
Give us a call if you have any problems and we would be happy to answer any questions.
Doug Smith
Doug Smith
unscrew the plastic breather cap. remove nut and lock washer bluechipdiesel.com has a gear puller for 50 bucks. i placed the key one top for removal and install with no problems at all. five bolts that hold the pump too the block. the injector lines in two groups three i changed my vp44 myself it was not to bad.
eichhoma
01-27-2019 12:39 PM
Dusty Ratcliff
05-22-2006 09:46 PM
texasaggie2005
08-22-2005 09:39 PM
