Swapping VP44 - auto vs 6 speed
Old 01-30-2008 | 09:58 PM
je27's Avatar
Any problems with replacing a VP44 on an automatic with one from a 6 speed?
Old 01-30-2008 | 11:13 PM
mini14's Avatar
I think u r o.k. the 6 speed i think has the h.o. pump which i also think can still be used on an s.o. but not vise versa.........if u have the pump # u can easily cross reference it to see if it interchanges.
Old 01-30-2008 | 11:17 PM
REF>Lancer's Avatar
I think that it works either way with the VPs(I'm only 90% on that),if you try and swap engines you need an automatic engine for an automatic,but automatic engine works fine in a stick.(way I understand it)
Old 01-31-2008 | 02:31 PM
stuckey200224's Avatar
im pretty sure you can only put the s.o pump on the h.o motor not the other way around. h.o pump on the s.o motor
Old 01-31-2008 | 06:30 PM
dozer12216's Avatar
Just put the correct one on and you don't have to worry. Cores become a issue if buying pump.
Old 01-31-2008 | 06:52 PM
je27's Avatar
Maybe I should provide more detail... I just bought my first diesel truck 2 weeks ago and I've discovered it needs an IP but I gotta have one CHEAP. I found a GREAT deal on one that's practically brand new from a 6 speed truck. I just need to know if it will work.
Old 01-31-2008 | 07:17 PM
dmscumnz's Avatar
Yes, it will work. Only difference is it puts out a little bit more fuel, and who would complain about that? You can even run the Freightliner Yard Mule 5.9 Cummins pumps on Dodge trucks - and it means a good 40-50hp.
Old 01-31-2008 | 07:19 PM
dmscumnz's Avatar
15x is standard output, 16x is 5-speed pump and 17x is the 6spd pump, I'm pretty sure. Back before the "hot rod vp44's", guys with autos were putting the 17x pumps in their trucks for the performance gains.
Old 02-01-2008 | 11:53 AM
Diesel-Dan's Avatar
027 is standard output VP pump (235 HP)
028 is the stock high output VP (245 HP)
029 is the VP for the 275HP ISB application's
As far as i know, you can only swap a 027 pump for a 028. I dont think it will work the other way around. AND i dont know why someone would want the HO 028 pump in the first place.....the 027 has more HP potential.
I have also been told by a pump shop that the 029 will not work either.....they said they get issues with the engine staring but will only idle. OR not start at all.
olskooldodge
07-15-2009 12:13 PM
West Coast
04-18-2008 12:25 PM
haftrek
11-12-2007 10:19 AM
ckennedy
09-27-2004 12:58 PM
