Stuck on shoulder. No pedal response
Stuck on the highway. All of a sudden, no throttle response from the pedal
Shut the motor off, waited 10 minutes, started truck up, throttle response back to normal.
Check engine light on. For the moment, the truck is driving as normal.
Any ideas or helpful hints please!
Timbos Apps is a far better solution $165.00 vs dealer $600.00
You can find them here http://www.dodgecumminsapps.com/about.html
APPS SENSOR INSTALLATION INSTRUCTIONS
1. Disconnect battery cables
2. Remove the plastic APPS cover.
Next remove the six, 10 mm headed bolts that hold the bellcrank assembly on. When that is removed, you will see the sensor on the back. A T20 Torx is needed here.
*Caution, these screws have loctite on them. So make sure that the bit is engaged fully into the screw head, so they do not strip, or you will need to use visegrips to remove them. NOTE: 2 new screws are provided.
3. After the old sensor is removed, take the new sensor and look at the side that bolts to the bracket. In the center, you will see the slot that engages in the tang of the bellcrank shaft. Next, line up the slot with the tang and push the sensor onto the mounting surface.
*If a sensor does not mate flat to the mounting surface, the slot is not engaged properly, try again.
4. When you are sure the tang is engaged properly, rotate the sensor clockwise, until the screw holes are aligned, and start the screws. Just before the screws are tight, twist the sensor clockwise and tighten the screws.
5. Remount the bellcrank assembly to the bracket.
6. Next procedure is setting the idle voltage, using a digital voltmeter, and turning
the idle stop screw clockwise.
*Caution, the screw has loctite on it from factory. You will need a T20 Torx bit with a ¼ inch ratchet to turn it. Make sure the bit is engaged fully into the head before attempting to turn. Be careful not to strip the torx head!
*If needed, a propane torch, VERY CAREFULLY, can be used to heat the screw; this will soften the loctite and allow it to break free. Only heat it for a couple seconds at a time and attempt to turn clockwise.
Next look on the back of the 6 pin electrical connector, it is numbered. With the paperclip provided insert it into the back of the connector PIN # 3 (Green wire). Or insert it into the back of the factory plug(light blue wire w/black tracer) just make sure its PIN #3. This will get hooked to the positive lead of the voltmeter. The ground lead can be hooked to the ground terminal of the battery. Turn your voltmeter to the low voltage DC scale. Make sure paperclip does not contact ground. Proceed to plug the sensor into the factory harness and then hook the batteries up. Turn the key to the ON position. Now read the voltmeter, it should read .580-.700. Next turn the idle stop screw clockwise, NOTE you may turn for a little bit before the voltage actually rises. As soon as the voltage begins to rise, turn the screw backwards ½ turn and you are done with the idle screw.
. To check the full throttle voltage, move lever by hand to full throttle. The voltage will be about 3.8V. Some voltmeters can vary a little so don’t be alarmed if reading are NOT to the exact tenth of a volt.
7. Turn key off, disconnect voltmeter, and pull paperclip out of pin #3.
8. Last procedure, turn key ON, press accelerator pedal slowly to the floor and then
let up slowly. During this procedure the ECM learns the new APPS voltage.
If you have any problems email Timbom1976@aol.com or call 717-577-1464.
JKM
12-12-2012 12:09 AM
