strange failure mode, high idle, dead pedal
Old 02-01-2006, 04:02 PM
docauto's Avatar
Sounds like the EDGE Comp is the way to go! I primarily use my truck for towing, but also have been using it lately as a daily driver (it's much more comfortable than an econo-box). I assume for heavy towing I assume I would adjust the power level for optimum EGT.
Ebay has several Edge Comps at $500, is there a better source/price?
Dave
Old 02-01-2006, 04:07 PM
mini14's Avatar
DTT web site has the CORRECT apps reset procedure.
Old 02-01-2006, 04:20 PM
docauto's Avatar
Hi, can you list a link? I can't seem to find DTT.
Thanks!
Old 02-01-2006, 04:25 PM
CTD NUT's Avatar
Dave
Yes sir, you assumed correctly....
With your 6spd truck which is equipped with the 12cm HX35, you won't encounter egt issues unless you are towing quite heavy with the Comp cranked. I never have my Comp set lower than 3x4 - ever. I have a 5spd 3500 also with RV275 sticks and have not really run into egt issues when towing heavy unless there are a lot of long, steep hills.....then, I will knock it down to 3x4.
I would not expect to find a brand new Comp for less than $500......just be careful with Ebay....Edge will not honour warranties if the "dealer" is some "fly-by-night" sketchy kind of dude.
Old 02-01-2006, 04:30 PM
CTD NUT's Avatar
Yup, they are the only ones that I have found that show the proper method to restting the APPS......for some reason, I can't log into there site forum where the proper procedures are listed.
The site seems to have some operating problems.....
Here is the link, anyway CLICK
Old 02-01-2006, 04:36 PM
docauto's Avatar
CTD Nut, thanks again for all the help. This forum is GREAT! Hopefully this high-idle, deal pedal issue will just fade away after an APPS reset. I've got a 10 hour tow on Saturday, we'll see.....
Old 02-01-2006, 10:13 PM
piperca's Avatar
Docauto, I can send you the info. for the DTT reset. I have it in my computer as a Word document ... also added a couple of help items I discovered during the reset. PM me with an email address and I'll hook you up!
Old 02-02-2006, 07:50 AM
CTD NUT's Avatar
Could you send it to me too? I can't log into DTT for some reason and I would really like to have the proper procedure for the APPS reset....I'll PM you.
Old 02-02-2006, 12:55 PM
amartinson's Avatar
Why doesn't someone get this apps reset procedure in the tech facts section so everyone has access to it.
Old 02-06-2006, 10:50 AM
docauto's Avatar
A quick update: After installing the FP gauge, pump relocation, big line kit (and a new fuel filter), I made a 10 hour trip this weekend. No problems at all, except for a high idle (1000rpm) after about 5 hours (which dropped to normal after turning off the motor and restarting). The truck pulled beautifully up Cajon Pass at 70 MPH, 32 psi, FP at 13, temp at 800 (measured just past the turbo) with a 5000# trailer. I'll still do the APPS reset, but everything is fine. This thing will really move, I'm looking forward to trading up from the old Van Aaken to the Edge Comp so it won't defuel over 20psi!
Thanks for all the help on this forum!
Dave
600 Megawatts
03-26-2008 07:09 PM
jmccart
06-12-2007 02:12 PM
vikingsven
10-29-2006 08:28 PM
billygoat02
12-30-2005 09:19 AM
mysterync
06-25-2005 02:40 PM
Quick Reply: strange failure mode, high idle, dead pedal
