stoopid noobie fuel pressure gauge question?
Old 09-05-2007 | 11:05 PM
motomac3's Avatar
just bought my first cummins. to be on the preventitive side i want to install a fuel pressure gauge. my truck is a 98 24v, but my fuel pump is not attached to the fuel filter assy. it is attached to the block and i have the metal lid on my fuel filter assy( the older style). my question is can i just put a T in the rubber part of the fuel hose going from the filter assy to the vp and run it to a gauge in the truck or should i spend the $80 for the kit that replaces the banjo fitting? is the kit REALLY worth it?
Old 09-06-2007 | 01:04 AM
Russ Roth's Avatar
On your '98 just take the plug out of the top of the filter for your pressure outlet.
Old 09-06-2007 | 01:51 AM
motomac3's Avatar
looks like there are two plugs in the top plus two banjos. does it matter which one plug? i think there is one closer to the vp if i remember right. will have to check tomorrow.
Old 09-06-2007 | 02:39 AM
Dinner's Avatar
I'm assuming your truck is a 98.5, 24 valve. And yes there is two fittings on top of your fuel filter canister (if they are the same as a 99). I ran my gauge into the fitting closest to the engine/vp. I'm pretty sure that this fitting gives you post filter readings (pressure after it is through the filter).
Don't mind the dirty truck, years and years of winter & salt=
Old 09-06-2007 | 02:44 AM
motomac3's Avatar
man thats awesome!! thanks for the pic. i am much more of a picture person. helps me to know it will be easier than i was trying to make it.
Mike L
11-26-2012 12:46 PM
dog rocket
10-29-2007 06:28 AM
RenegadeT
02-18-2005 03:07 PM
Superduty12v
08-25-2004 03:11 AM
clc900
19
02-22-2004 11:51 PM
