still have serious dead pedal
new carter lift pump, reset apps, reset apps with volt meter put to .560 or close to.
still have po121 po1693.
new Apps from dodge 408.44 cash and still has dead pedal.
the injection pump is only about 2 years old. I cant imagne the vp44 going bad because the truck has to much power and runs way to strong.
"only runs good when I turn the ignition off and then back on while driving",, it kinda hard when pulling a trailer and trying to make a turn.
Do you guys think I could return the new apps and get my money back?
Manuel dodge in richardson tx.
Could quite possibly be a dying injection pump. Rjohnson had one dying on him and he had no symptoms other than he dynoed about 100hp lower than what he expected so it's definately something to consider. Do you have any idea what your fuel pressure is?
fp
Yes
current Fp is
Idle 15-17lbs
Full throttle edge turned up 7-8lbs
before the recent lift pump
idle was 12-13lbs
full throttle was 2-4lbs
ouch
always have run diesel klean lub. fresh fuel filters , many tanks of 80/20 bio soy.20 percent soy.
current Fp is
Idle 15-17lbs
idle was 12-13lbs
ouch
440FURY
01-16-2009 04:34 PM
600 Megawatts
03-26-2008 07:09 PM
dsljunkie
20
09-13-2003 01:54 AM
