Startup Oil Pressure
Since I purchased the truck in Feb, I've noticed it takes what seems longer than normal for the oil pressure to build and show on the dash gauge....even to the point where right upon start up the "check gauges" light is on and then after about 4-5 seconds the gauge jumps up to normal and the light goes off. Yes, it's full of oil. I know startup is the most critical for oil delivery but was wondering if others have the same issue? Thanks for your $.02.
Yes, all connections are tight and no corrosion. Batts are about 1yr old but I understand your reasoning. It just seems the oil psi should jump to normal almost right away even w/the engine warm. Maybe I'm just over reacting but I've never come across this w/other motors gas or diesel. thanks for the .02. Jared
i have noticed and i think i have seen on here before that dodge made them that way. it takes about 3 or 4 seconds for mine to work. none of dodge's gauges are all that accurate. you should be fine
My 98.5 does the same thing. It is because the oil pressure sending unit is located high on the engine, and does not "see" pressure right away. There is oil pressure as soon as the engine starts turning, it just takes a couple of seconds for it to reach the sending unit to tell you you have oil pressure. No troubles. I searched on here and found that it is common on the early engines, and nothing to worry about. My friend's '01 and his brother's '02 show pressure right away. But I think the later ones were "fixed" so people would not worry about the delay.
crackcorn
11-04-2009 07:02 PM
GlennRMK
05-24-2007 10:46 PM
