Starting
Starting
I have a 2000 Ram 3500 with a Cummins and a 6 speed, it has quit starting with the key switch, if I jump the solenoid terminal to the battery the starter runs and starts the engine. What should I look for to correct this issue?
Thanking you all in advance for your advice,
David
David
Double check the little wire going to the starter and it's connection terminal to the starter. I'd also ck this wire for (+) when in crank mode. If no power, I'd back track to the fuse box under the hood...tracking things back to the ing switch. Good luck!
fourthandgoal
88
12-27-2011 05:39 AM
abc4yew
03-15-2007 11:55 PM
