Stalling
Originally posted by 13FOX
What other type of maintance is required to keep this thing alive?
Yes I know i need some guages. I am going to get some when my truck gets here to Germany. It will give me something to do on the weekends.l Just ordered a BHAF. It's an AFE filter w/heat shield and recharge kit. It will let the old girl breathe a little better. After the guages, going to order a new torque converter then a FASS to complete the projects for the rest of the year. Maybe the FASS mite come first, cuase the trans is still strong as can be even when I have dogged the crapp out of it after the mods.
the update
Originally posted by roadranger
Be interesting to see if the dealer considers the Fass to be a "major" mod to the fuel system and voids the warranty...
Let us know!
Let us know!
Fixed...For Now
Took it to the 5-star today. They replaced the lift pump as it was only putting out 3psi. I talked with them about the injector pump and they said in about 30% of the cases of lift pump failure, the injector pump will fail soon after...but until it fails, they are not able to do anything further. Gotta love it...
The service manager went on to recommend that fuel pressure gauges be installed (They are currently recommending / doing this on all new / used diesels that they sell). Also, when the truck is out of warrantee, install a FASS.
It looks like I've got 7 months and / or 14,000 miles to have an injector pump failure...
Thanks to all that have helped....
Well... I left for work with the intention of dropping it off to have the FP checked and to see what new codes had arisen. On Friday it acted up 3 times on the way home from work. Got 2 miles from the house this a.m.. stopped at the light to get on the freeway.. coughed twice and died..
Had to pull the pig home with a little v6 Ford F-150.. and then had to drive it to work.. gawd I miss that big ol truck... anyhow had it towed to the dealer.. will let y'all know tomorrow what was the verdict.. wish me luck..
(out of warranty w/170,000 miles)
Grizzly Bear: So are you having any more dead pedal or white smoke problems after the lift pump change or what? you left the biggest detail of all out ..and BTW guys, mine has not set the 0216 code yet and is doing the same thing, just a check engine light now and dies in the morning.
So far so good
I have not had any further problems...yet. I am expecting the injector pump to die some Saturday night, either in the rain or snow, a million miles from anywhere.
But for right now it runs normal. No dead pedal, no smoke, no problems starting, no missing.
