Squished my thingy
Squished my thingy
I was upgrading my torque converter last night and what a job! It’s definitely more involved than dropping a 350 TH in a chevelle. It probably didn’t help that I did it in my yard and on an incline. That tranny with the transfer case is heavy! Anyway I tried to get away with not removing the cross member and sorta dropped the tranny on the cross member (hint: floor jacks don’t work well in the grass and on an incline) and squished the thingy with two wires coming out of it. It’s towards the bottom of the trans. and has a coil inside. Is this a temp sensor? Or does it play with the O.D.? Can I drive without it until I find a replacement? I guess this proves what my wife says is right, finish building the garage before playing with the truck. I think I still have ATF 3 in my ears. Oh, 1998.5 auto 4x4
Not sure what it is, but you scared me at first....I had a flash back of when I was 5 and could barely make it over the rim of the toilet and had a squishing accident with the toilet seat
That's just WRONG!
Originally posted by phox_mulder
So, what's better, a squished hootis, or duraliner on the hootis?
phox
phox
Speaking of squished things, how are you doin' Phox?
~Rob
Then after a semi good night sleep, it hurts like heck again.
Hardly notice the road rash, unless I scrape up against something.
phox
4x4 works fine. But it shifts different now. I waits longer before it shifts when accellerating normally. When I accellerate hard it seems to shift normal. Could this be due to the new torque converter? Or is this the result of the sensor squishing?
