Special Tool To Remove Injectors?
is there a specialty tool needed to remove the injectors, if so how much is it and where can you find, i was told that it costs $90 HA, i doubt it, but u never know
heres the site i got mine from
http://www.tooldiscounter.com/ItemDi...e&kw=OTC217793
that's the adapter you will need on top of the slide hammer they sell. the adapter is now 80 dollars i think, ridiculous if you ask me. if you get a piece of pipe wide enough to fit over the injector.take one of your lug nuts from your wheels and thread it on the injector(they are the same thread size). start tightening it until they pop up, cheap injector puller and works great. you could always use vice grips as well.
Since your sig shows a 2nd gen, I'll assume that's what you're working on.
Use one of your valve cover bolts and thread it into the injector. You can then carefully pry the injector out.
Or you can make a simple adapter for your slide hammer to pull on the bolt.
I'll post a pic in my gallery to give you an idea.
Smokin96_12v
07-29-2010 11:19 PM
mitch89445
02-18-2009 08:48 PM
megajoltman
01-07-2008 07:54 PM
Jambbii
09-28-2004 08:41 PM
