schrader valve
schrader valve
I'm installing high flow banjo bolts on my '01 cummins and I want to keep the schrader valve at the test port location for the dealer or cummins techs to be able to check the fuel pressure. Does anyone know where I can get a schrader valve to put into the tapped banjo from genos? I tried Rod at wildcat, but they don't sell them anymore. Thanks.
Yeah, we have them on our international trucks at work. International calls them a priming valve, part # 1816216C1. It's 1/8 male pipe on one end and a schraeder valve on the other. If you can't find one local, pm me and I can hook you up for about $20.
There is a cap on the trucks. I'm not sure if the new part comes with one or not. It looks like a tire valve stem, maybe you could put a bling bling chrome cap on it.
Does anyone know the size of the test port on the vp44 pump. Is it metric 11.5mm or is it SAE 7/16.or is it AN size? I would like to know so I can buy the correct size female shrader to adapt to my SS braided fuel line which leads to the isolator.
I PASS GAS
14
10-02-2006 05:02 AM
CTD2001
13
06-02-2005 03:33 PM
