runs rough
yes. p1688.p1689,p0251,p0252,p0253,p0121.p1689-no com.between ecm and injection pump.mod. Could ecm be bad or is the injection pump at fault. Other codes refer to pump. p0121 refers to apps. voltage with map
read this first:
http://www.bluechipdiesel.com/vp44diagnostichelp.html
According to the link I posted your truck should not even run...so My suggestion is to clear the codes run truck again to see what codes re-appear, you could have a bunch of past history codes showing.
If you need a TPS/APPS do a search for "Timbo " he as a cheaper version that is a direct replacement for 160$ vs the 400+ you will pay anywhere else
I'd bet your going to need a VP
Jambbii
10-08-2006 04:12 PM
