Running cold
Running cold
My issue: Engine and transmission running cold. Less than 130 on the transmission, and less than 150 on the engine. The transmission is less of a concern than the engine. I changed over to synthetic in both, and immediately noticed the drop. The engine got to 150 while towing our 3 horse goose neck, otherwise it stays at a needle width above 140. The performance (mpg) is down slightly, maybe 1-2 mpg. The heater is lacking a lot, so I suspect the reading is accurate. I checked codes and only get a 1688. ( had that one for 18 months now) I did the cluster check and it appears fine. I've read mixed reviews regarding temp. drops with synthetics. There is a new belt, new filters etc. I'm suspecting the sender but don't believe in coincidences. I'd prefer the engine run at 170-180, and have a 3000 mile trip coming up. What am I missing? Thanks
Thanks
Thanks Dieselcowboy. Sometimes I get too close to see the problem, then I over think. Now that you mention it, that sounds logical. I'll get a t-stat with the other items next on the list. Have a good weekend
Thanks again
I'll go to cummins in the morning or monday and get the proper thermostat. I researched the forum and found answers and pictures. Thanks Dodgecowboy ( I mistyped previously) and sixslug.
akhunter68
10-31-2006 05:07 PM
joel
01-22-2005 08:59 PM
BEHRMAN
12-24-2004 11:05 PM
