RPM's at freeway speeds.
I need some help.
My truck is not stock as you can tell in the sig.
I need to know what one of these trucks will run with stock or close to stock tires, auto trans heading down the freeway at about 70 mph.
With 38's and 4.10's Im right around 17-1800.
I'm thinking my converter is way to tight stalling @ 1200 but I need some "stock" rpm info for comparison.
Thanks
Dan
Thanks
Dan
hope this helps...
http://dodgeram.org/tech/specs/axle/47auto.htm
it will atleast tell you the stock numbers you are looking for.
For comparison, I'm running 235-85-16s and a 4.10 gear.
Indicated 60mph is ~2000 rpm.
(truck came stock with 215-85-16s)
I appreciate any advice offered!
John
Before swapping from 3.55's-4.10s this is r's I was looking at, with the 265's on in sixth gear I was running 70 at 2000rpms. With 315's, I was running 78 at 2000rpms. 4.10's, 255/85/16's I was running 2000 rpms at 65. With the 315's on at 70 I am turning 2100rpms. Fuel economy has gone down more that I thought it would for highway cruising. usually run 73 or so. Looks like I need to get a US gear overdrive to take me back to the happy spot of 80 at 2000rpms. Any questions on gears and rpms, I have had many different sizes of tires on my truck and can tell you what rpms.
smiller
05-30-2004 05:54 PM
Slice
03-16-2004 09:13 PM
fishin fever
02-22-2004 08:32 PM
