RPM drops and check eng. light on
Old 12-12-2012, 07:32 AM
Joe Diesel's Avatar
Originally Posted by Woodhauler
Tried two of them just incase one was bad out of the box, joe no good still does the same thing. It has to be electrical or ecm. Hate to buy ecm and that not fix it. Thanks
I still got both codes 0341 & 0342 after i changed the sensor. Next im going to check the voltage from the ECM to sensor then clean all the contacts on the ECM.
Old 12-12-2012, 06:03 PM
Woodhauler's Avatar
Originally Posted by Dieselbuilder
how old are your batteries? Have you checked fuel pressure, clogged filter,air intake. any smoke from exhaust, valve set? grasping straws here??
grasping at straws yes, have checked all mechanical side, sensor ring on back of cam gear, did over head all settings there good. no smoke from exhaust out of norm. fuel pressure at a constant 11psi. One battery is new the other is orginal was planning on testing but meter shows it is good. Dodge says it is the pump but I have replaced with a known good one and truck still does the same thing. Not sure if I want to spend 700 on a new ecm or not, not convinced thats the problem.
Old 12-12-2012, 06:05 PM
Woodhauler's Avatar
Joe i think you should have 5 volts going to the sensor. I checked mine and also checked wire harness from sensor to ecm for shorts to ground and resistance. All good on mine.
Old 12-12-2012, 06:36 PM
Dieselbuilder's Avatar
Rule one never ever just change one battery ecm are sensitive on voltage its no different than trying to run your computer with a generator
Old 02-20-2013, 02:21 AM
DeTree's Avatar
did you ever resolve your issue......mine is losing the tach completely for a while, sputtering.....I am thinking a bad ground somewhere and surging
jefjsak
01-15-2015 03:44 PM
southerman
05-22-2012 06:18 PM
2Armor
15
03-01-2010 03:37 PM
MYBIGREDTRUCK
07-31-2008 07:46 PM
JVDodge
01-27-2008 10:30 PM
Quick Reply: RPM drops and check eng. light on
