rplaced my apps but still getting code po122?
Old 03-20-2009 | 12:53 PM
nasty01cummims's Avatar
whats going on? My truck runs perfect i can tell a noticable difference in power. do i just need to recheck my conections and stuff like that? oam i just gonna have to live with my CEL ON?
Old 03-20-2009 | 01:09 PM
bump bump
Old 03-20-2009 | 03:02 PM
Busboy's Avatar
Did you clear the code? If so try an APPS reset.
APPS Reset Procedure Answer:This procedure has shown to help 24 valve ISB engines. It is basically teaching the fly by wire accelerator on these trucks to reread the position of the pedal and it's limits. Most complaints this will help with is poor acceleration, improper shifting, bucking in 5 and 6 speeds. Has been known to increase fuel mileage in some instances.
1. Set parking brake
2. Disconnect negative battery cables on both batteries
3. Turn ignition key to run(to drain any remaining capacitors)
4. Let truck sit for 30 minutes( this is the recommended minimum)
5. Return ignition to OFF position
6. Reconnect both batteries and secure, not a timed event
7. Turn key to run position(not start) and depress accelerator pedal slowly all the way to the floor
8. Allow pedal to return to top position slowly
9. Turn ignition switch OFF
10.Release parking brake
I just noticed the other thread you have going and you say you don't have a scanner. You can buy ones cheap $40 Canadian so probably cheaper in the US. I've also read that some US auto parts places will read and clear codes for free.
Slugblaster
07-30-2012 09:11 AM
southerman
12-17-2008 07:21 PM
FastTaco
04-13-2008 04:07 PM
STACKED
03-04-2007 07:13 PM
chadwick
11-04-2006 02:57 PM
