Rough idle problem after everythings been changed
Well I've had this problem for about 9 months. I replaced the lift pump (with a PPE 165GPH), put on a big hose kit, put in a FP Gauge, etc... Problem didn't get any better. That was about 5 months ago.
I finally saved enough money (we don't get much work in the winter), bought a new set of injectors, and installed them today. Even pulled the radiator and pressure washed it clean and flushed all the coolant. Well, I installed a set of RV275's got everything back together, fired it up in the driveway (trying to burp the cooling system), and it sounded like a 24V should at idle. Sweet! Buttoned things up, took care of the tools, etc. Got back in to take it for a test drive, ran it good and hard for about 6 miles, and every time I let it idle it was back to its old self, a miss or lope, rough idle, I don't know how else to describe it. Its really only when the engine is warm, cold it seems normal. Now, the old injectors were original at 230K miles, so I am happy I changed them anyways, but I want this thing to run smooth like it oughta!
Sooooo... I don't know whats left besides the pump itself, and I don't have a grand to drop on a new pump if I really don't need it. The thing fires right up every time, and its got plenty of power, so I don't think its really the problem, but I really don't know.
I'm going to say it's the pump.
When its cold, the fuel is thicker so the pump's leakage doesn't show up. It has no problem making enough flow to pop the injectors open properly and consistently.
But with hot fuel/warm engine, the fuel is much thinner and the pump can't meet the demand. It's running out of capacity and you are having the problem you describe.
There's no fault code for "pump not flowing enough". The ECM on these things has no feedback at all as to whether enough fuel is flowing or how much pressure is in the fuel line and such.
JH
JH
Question: Did you have this idle problem with your old injectors? I didn't, and mine had over 160k on them. Only reason I replaced was the tech showed me the inconsistencies when they were being pop tested and suggested new ones.
Yes, I had the same problem with the old injectors, its honestly one of the biggest reasons I changed them. I'm betting its the pump too at this point. but the truck runs fine, and under load its not a problem. (Although its probably loosing a few ponies because of this). I'll replace it when it dies completely, and not before then...
DBlack1
14
10-27-2013 01:06 PM
el toro
12-23-2012 01:45 AM
chuxtruk
06-11-2007 05:38 PM
digbog
09-02-2006 07:57 PM
natlchamp2k4
16
02-22-2006 03:39 PM
